Grease
The type of grease I used when I reinstalled the rudder was common automotive bearing grease the type you'd use on ball joints, U joints, etc. After all, those auto components are exposed to salt water (michigan winter) and harsh dirt, sand, heat,and so on.The grease fitting is a common zerk fitting that you can service with a grease gun and a flex hose.Mike
