Rubber window seals?
Rob
I ve just bought a c22 1977 and the seals around the windows have shrunk (outside)any suggestions on where to get new seals or an alternate solution to this problem thanks Rob
L
LaDonna Bubak - CatalinaOwners.com
Check the archives
There are about a jillion threads in the archives regarding rebedding your ports. I think the concensus is to use butyl tape. You can buy it at RV stores. LaDonna
steve c
windows
i had the same problem call catalina direct they have the window seals i ordered both packages cost 40$ took my windows apart went right back together with new rubber seals they were not leaking but the seals were shrunk and cracked and did not look very good so i replaced them
