Hi.
I've decided to go with a simple A frame formed from 2 galvanised steel
tubes (1 3/4 inch inner diameter), 6 metres in length (about 20 feet).
I've drilled 10 mm (1 cm/0.4 inches) holes near the tops of the poles to
take a bolt which allows the frame to pivot at the top.
I'll guy the frame fore and aft.
I'll secure the feet of the A frame to the forward U-bolts on side deck.
(I should "chamfer" the feet so they rest flat on the sidedecks.)
My only (for now) remaining issue is how to protect the side-decks from
the feet of the two legs.
One suggestion - just secure wooden pads to the deck before resting the
legs on wooden pads and securing?
Alternatively: source heavy rubber "shoes" to fit over feet of the two legs.
Or tapered wooden pegs hammered into base of each leg??
Any suggestions welcome.
John V1447 Breakaway
John A. Kinsella Ph: +353-61-202148 (Direct)
+353-61-333644 x 2148 (Switch)
Mathematics Dept. e-mail: John.Kinsella@...
University of Limerick FAX: +353-61-334927
IRELAND Web: John Kinsella's Website
