Rub rails
Sep 10, 2013
5
S2 9.2 Holland
I picked up an 1982 S2 9.2 that needs a lot of work. One area I would like to clean up it the rub rail. It's in pretty rough shape and I'm not sure how to restore the color back to black. First of all, what is the rub rail made of, aluminum? Secondly, what would you recommend for cleaning/polishing it? Right now its streaky white and black. Thanks.
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
We tried Meguires products, Mothers products, and some others I don't remember....Acetone worked the best with a coat of wax after..
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Do you mean the toe rail? The rub rail is the rubber bumper that goes around the boat. The toe rail is the slotted aluminum edging. The rub rail is best cleaned with acetone followed by a protectant. The toe is black anodizing. Not too much to do except clean it avoiding abrasives. Some report luck with a couple of thin coats of Penetrol, sold in the paint aisle of your local hardware store. Don't over do it as too much results in a sticky dirt grabbing film. Lime away was recommended as a precleaner and for removal. Saw it on a Hobie site. Others recommend just oiling it after cleaning it with dish soap and a white scotch brite pad. Dormond is sold to clean black anodized Calphalon pans, so you might try that, but i have some and must say it doesn't seem very effective on pans.
Sep 10, 2013
5
S2 9.2 Holland
Acetone along with a wax protectant worked great on the rub rails and Penetrol worked great on cleaning up the toe kick. Thanks for the advice!
Jul 7, 2011
22
S2 10.3 westbrook
My rub rails are almost white with oxidation.. We're yours that bad and did the acetone get the rubber back to black..
Thanks
BobM
Jun 10, 2004
3,269
The acetone will take them back to black from all white.
