Rudy at D&R Marine has a white rubrail and black insert available, you will need 3 sections of rub and the 60 foot section of insert. You can also try West Marine but I think they only carry one type of white rub and it has a white insert. If you are looking for an exact factory replacement, I dont believe they are available anymore, however there are some that are very close. I would replace it with one that I liked of the same dimensions of the original and go with it. If you are wanting a white rub like the original, be careful when ordering. Many companies list kits as white, but the rubs are black with white inserts.Good Luck.
