rub rail replacement
8
hunter h26 okanagan bc
Would anybody know what I would need to replace my 2 pc damaged rub rail on my 1994 hunter sailboat?
May 28, 2009
764
Hunter 376 Pensacola, FL
Re: Here Are My Note From My Search
While we're on the subject, a thought occurs to me. The rub rail I often see people trying to find is no longer made, but does anyone know if a newer profile would work as a replacement? My '95 H336 has an outward flange hull to deck joint - do the new boats still use the same type of joint? If so, I wonder if it might be possible to order the newer (and still in stock) rubrail from Barbour and just replace the whole thing rather than trying to have some of the older type made.
Oct 25, 2008
8
Thanks rick! I ordered a new rub rail for $240 and it should arrive any day.
May 28, 2009
764
Could you do an update when your rubrail arrives? I'm curious if it answers my question above, about whether the newer profile will work on the older boats.
Oct 25, 2008
8
I plan on picking it up tommorow and will let you know how it works out.
