Re; rub rail
Don: E-mail me and I'll give you my Phone # and we can Make arrangements for you to see them. jamesrohr@msn.com. oops. I thought reply was from fellow in Joppa,md. It would be a long trip from Ont. I'll look around and see if I have any upclose pictures. Basically I started w/ 3/4x2" oak. rounded two outside edges w/router. then here's the tough part. you need to rabit the back side to allow for the hullto deck joint. about 3/16 deep. leave about 1/4 to 3/8" full thickness at bottom so when its fastened it stays close to hull. I also uced two 16' pieces to min. joints. make seam fore or aft of stanchion. after inst I seal top w/acrl latex caulk, then wipe excess of with wet rag. dont caulk under side. it will trap water behind and affect longevity of finish. I learned this the hard way. I installed them w/ss screws, 6"o.c. drilling and fastening as I went. Its a good idea to go back and cetol in the drill holes and touch up over screws after inst. I found that sickens cetol#2 gives the longest and most durable finish. also stain to your liking. the first time their installed you'll need help. they want to stay straight. after that its easy because they take on the shape of the hull. toughest one to deal w/ is the one on the stern since its so short. oh! one more thing make sure wood is clear. No KNOTS.
