Jerry
Well it rained hard last night and I was able to find a couple more leaks and check were I had fixed some. Seems the major leak is coming from the cockpit drain. I'll mix up a gallon or two of water with food coloring and pour it in the cockpit to see what's there.As to my questions - what is the profile of the rub rail for an '86 H23? I'm considering replacing mine. I contacted Taso and Hunter -- they were no help!!!Second -- I'm replacing the fixed factory motor mount with a Garelick mount. I'm currently using a Nissan long shaft 8 hp. Can anyone tell me where it should be mounted with respect to the old mount?Last -- isn't it funny but why do boat makers mount the motor on the port side and the gas cuddy on starboard? Design/engineering/weight distribution issue???
