Rub Rail Cleaner? Acetone??
rfrye1
Jun 15, 2004
589
Hunter H376 San Diego
Trying to clean up the Rub Rail on my Hunter H376. The only thing that cleans it is acetone. But using acetone is a pain, it evaporates so fast. Does anybody have another solution? Mineral Spirits doesnt work.
Thanks. Bob.
Dec 2, 1999
15,184
Have you lookoed at Island Girl Pink or Aurora Marine for some other alternatives. Acetone is usually a quick fix, but will sometimes make the rub rail soft.
Mar 19, 2006
87
- - South River, Chesapeake Bay
Island Girl
Steve is right ...... the Island girl product "Sea Glow" works great on the rub rail.
Jun 4, 2004
834
Hunter 340 Forked River, NJ
I use a Scotchbrite pad with a good spray cleaner for the rub rail. That handles most of the grime except where i have some rubbed up against a piling or something dirty and greasy - then I use some acetone on the pad and scrub like mad before the solvent evaporates.
Jun 7, 2004
263
- - Milwaukee
The rub rail on our 356 is some sort of vinyl or "rubber." Not sure what yours is, but I've had very good luck on mine with a little of the "7" polishing compound sold for cars. Stays clean, too.
Ray T
Jan 24, 2008
224
Hunter 216 West End - Seven Lakes
Try some white sidewall tire cleaner. Do a small section, rinse and move on.
Jun 10, 2004
13
Hunter 420 Punta Gorda, Fl
When our rail get real bad, I use a palm vibrating sander with 220 grit paper.
John WFD
Try this>>>>
I use Colonite metal Cleaner/Wax. It rubs on easy and removes all the grime. You'll use a lot of towels doing the whole rail, but it last season to season.
Alan K
Feb 22, 2004
54
Hunter 380 Norwalk, CT
A product called "Greased Lightening" will make your rub rails look like new.
