I have an 02 Hunter 270 with the Yanmar 1GM10 diesel, which I have owned just over a year. She starts immediately, runs fine, but on the last two outings after running under power back to the marina (15-20 minutes near full throttle), she runs rough and will barely idle. Today I ran the engine for about 45 minutes and when throttling back to enter the marina, she died at idle. Started her back up and she would barely run, then started banging every few strokes. I sailed her into the slip on the jib and am scratching my head. A slip neighbor recommends a bottle of injector cleaner, but I would like other opinions.
The only maintenance I have performed in the year I've owned her is an oil change and air filter cleaning. She has an 11 gal diesel tank and consumption is very low as I'm on an inland lake. Could it be fuel contamination/condensation? (Wouldn't that make it run rough ALL the time, not just after running an extended time at higher rpm?)
Any thoughts appreciated.
