C
Chief
Started up the boat this afternoon and no more rough idle. I did not touch a thing. Then I noticed that as soon as I put even a slight load on the alternator the rough idle came back and I had to rev the RPM's slightly to smooth it out. Should I just advance the throttle linkage to have her idle at a slightly higher RPM or is there something else going on with the alternator? The engine is a Universal M25XP with the standard Motorola 55 Amp. I did purchase a new Leece Neville 72 AMP with Balmar MC-612 Voltage Regulator but got cold feet last year about installing it myself. Both parts are sitting under my desk as I type this. I did locate a highly recomended Marine Electrician who is willing to do the work. He just could not do it in my winter yard. The though keeps popping into my head "if it aint broke, don't touch it". Would replacing the alternator solve the "load issue" on the engine or make it worse? The only load on the alternator was my Depth, Speed and Wind along with my GPS.
