I have a 1986 catalina 36, the front starboard side engine mount is loose.I can pull the bolts out by hand.is there wood in side the area where the engine mount is supposed to be screwed to, and what is the best fix?
I too had this malady when I went to remove the engine in my C-30. In my case I had a bolt completely corrode off leaving part of the threads in the hole.I removed the rusty bolt remains by drilling a smaller hole in the bolt and working an easy-out into the shank and unscrewing the offending part. I used some small teak shims and installed a new stainless bolt into the hole along with some West System epoxy with filler. I sprayed the shank of the bolt with Pam as a poor man's "mold release".The bolt is now in solid and can be removed if necessary. It's been fine for the last 2 years.Good Luck!
