Just trying to figure out if I screwed up...Just changed the oil and filter and I used Rotella T1 30 weight. I just found out from a friend that has the same engine that he uses 15w-40?
I was afraid that the requirements would be different due to the turbocharger. I have put only 7 hours on the engine since the oil change. When I switch back to the multi-grade in a month or so do I need to replace the filter as well or should that be ok to leave?A yanmar turbo diesel has very different lubrication requirements than a normally aspirated yanmar. The turbocharger's bearings need immediate full lubrication at start up. That means a multi-grade lubricant to Yanmar's spec, changed more often and never 30 weight in the winter.
Yes, change the filter, when you change the oil grade.I was afraid that the requirements would be different due to the turbocharger. I have put only 7 hours on the engine since the oil change. When I switch back to the multi-grade in a month or so do I need to replace the filter as well or should that be ok to leave?
I agree with Chris but isn't funny how an engine manufacture such as Yanmar states changing the filter every other oil change...An oil filter should be changed at EVERY oil change.
I can hear the crickets in the background..
No offense, but how much oil do you think you leave in the pan everytime you change the oil?Well you would want to change it in this case to make sure you get the different oil out.
