Rotating trailer tires
DJN51
Oct 26, 2009
377
Hunter 23.5 East Chicago In
Over the weekend my daughter burned out a bearing on her horse trailer,had to cut wheel off as it got so hot it welded to hub,so my wife had our trailer mechanic repack her trailer bearings, during our conversation asked if we wanted tires rotated,never have on all my boat trailers.Has anyone done it,Oh he didn,t charge me since the tires were off anyway.Just curious.
Jul 8, 2011
704
Catalina 30 Sidney B.C.
Should do it as all spindles are welded slightly diiferently to the axle tubes and rotating the tires is just like your car , the tires wear longer
Dec 5, 2011
552
Catalina Catalina 22 13632 Phenix City
Are we talking single axle or dual axle trailers here? I always heard radial tires should never change sides on rotation as they "take a set" after a while and should only be rotated front to rear and rear to front and kept on the same side of the vehicle. I was always told changing the running direction of a radial would cause premature failure. Having been around the block already on exploding trailer bearings and flat tires, I'd like to take any steps to avoid sitting on the road shoulder again..... Any tire experts out there know something about this?
May 1, 2011
4,906
Pearson 37 Lusby MD
This . . .
'I always heard radial tires should never change sides on rotation as they "take a set" after a while and should only be rotated front to rear and rear to front and kept on the same side of the vehicle' - is an urban myth. :D
Oct 21, 2011
109
O Day Mariner 2+2 my driveway/ Lake Wallenpalpac
Years ago when I was a kid fresh outta the army, and working my way through auto mechanic college (Johnson College), at Sears, they had a guy come in to give us all a class on tires.
THEN, we were told, a radial tire has wires, (cords sets) that will "move" in the direction of the rotation when the tire heats up, NEVER cross roatate the tires as they (the cords) will start to move and buckle.
Firestone had a problem back then with the 721? tire, that the cords buckle up and wiping out the tires, (I did a lot of recall tires when I was a working wrench for Chrysler after grad-E-tatiing).
(I had "borrowed" a set for my Dodge Powerwagon I had at the time, and blew the fronts on the interstate one fine day)
Bias ply was OK, but not radial.
Now flash forward 32!!!! years and tires design have changed, alot.
Radial CAN be cross switched with little or no problem, (my son just grad-E-Tated from the same school, weird for me!!), he had a tire class whilist there and was told that.
That all being said, I still don't cross rotate my radial tires on my trailer(s).
I've been hauling motorcycles to races all over God's green earth since '75 when I got my license, (well short of the 3 years I was in the "green weenie").
There were some years I'd put 40,000 miles on my trailer and van, ("Hotel Dodge")
I've never had a set of trailer wear out, blown out, yes, dry rotted yes alot, but worn to the skins, never.
If your wearing tires out, your axle is outta alignment, spindle bent, etc.
Best thing is tire PSI keep them up to what ever they call for, pack the bearing each year (Always new grease seals when you do them, (I give my "Grease Buddies" a few shot EACH time I dip my tires in the H2O.
Joe
1, Take any advice given with a beer and
2, Remember some people said the stock market could never crash, the Titanic was unsinkable!
