No Sink
Sorry for the delay but I have been busy figuring how to put things back together in a different configuration. The sink is gone; this will now be the Nav area, electronics will be in the new cabinet and the sink area is now a chart table, it can easily take a folded chart in the event of electronic failure. The half bulkhead is coming inboard almost to to the underside of the cabin side. The lower section has been glassed to the underside of the port settee, this has maintained the rigidity and should give the same structural integrity. Also the old plywood bulkhead was completely remove, leaving only the fiberglass tabs in place, to which the new plywood was inserted and re-tabed to the hull, actually I think that is now a stronger attachment than was originally done. Once you delve behind the exterior cabinetry etc, the early workmanship was sorely lacking, perhaps still is.I'm keeping a photographic record of the changes as work progresses and shall post them when completed.Robert
