What About Neither???
Actually, I'm kinda venting a bit. When I got a new 110 the question came up whether it should be a reefing jib or not. Given the number of times in the past that I had to reef it in a bit the idea seemed like a good one. Few extra bucks but what the hey - it's a boat, and besides, being able to dial in a reduced sail sounded good. And besides, you really don't want to go changing down to the storm jib when things are really nasty so we went with it. I opted for foam in this case for easier folding.Now the years have gone by (about seven of them) and I can't recall ever using the reefing option! Don't know why - maybe I'm staying in the harbor more often if the forcast looks bad, or maybe the jib has a flatter cut than the original one, or maybe both. Anyway, if I had to do it over again I wouldn't.The argument against foam was mold and mildew (haven't had any - see picture at http://www.sailboatowners.com/forums/fpix.tpl?xfno=122&uid=F&rid=2005327111445.21 , and that it could/would get hard (don't think it's changed any). On the other hand I take the sail off for the winter so that eliminates about half the year of exposure to elements. The loft (North) seemed to be trying to steer me toward rope but in the final analysis it was really my decision.The 150 is a little different story though because you're really looking at light air which can have a good probability of becoming stronger so this might be a different story.If you decide to go the foam/rope option for a reefing jib then be sure to go with heavier sail cloth so the sail doesn't get blown out so quickly. One of the killers of 150s in my opinion is those periods of intense winds you get when the wind is funneled around land masses and you have a lot of them there. Looking ahead you can see flatter water so you say to yourself "If only I can make it through this area it'll be okay." and that's the kind of winds that wind up overloading the sail and ultimately blowing it out. With the stronger winds that are more spread out the skipper will most likely change headsails. Being next to Haro(ing) Strait it's easy to see what's out there, especially at high tide.From a mold/mildew perspective, I don't think Sidney get's as much as we do so that's a real positive.The 150 is a great sail to have but something to also consider, if you don't have one already, is an asymetric. A big advantage of the asymetric is you don't have to change headsails but they aren't as good for going upwind like the 150 is.New sail - ohhh so nice!
