Main Furlers
Tom,There are several on the market to retrofit to your mast and size boat. Facnor, Forespar EZ-Furl, and Seldon(Furlex). They range in price starting with Facnor at the bottom. The design, mounting and finished look varies with each. Check them all out. The other post's are correct in the fact that a new Mainsail will be needed for use in any of these furlers, but that is the least of the expenses incurred between, the unit cost, installation and sail.If you like your boat and plan on keeping her, then check these out. They are generally much less expensive than furling booms.
