Winch!?
Rob,I have the same boat. Al is right.When you do this in the slip, you'll be amazed at how smoothly the thing runs, with no wind pressure on it.Look at the standing rigging on your boat, then compare how sturdily your furler is built. They're just not made to be used under the same kinds of strains. It doesn't take much pressure to make that genoa difficult to wind in with the relatively small drum diameter: doesn't give you much mechanical advantage, as has been pointed out below. Reducing the pressure on the sail is the keyOn light days, pinch up and roll it in. But when there's a fresh breeze, I always use Al's technique described quite clearly below. (If I have crew who can man the furling line and genoa sheet simultaneously, this can all be done in one fluid maneuver). Keeping the genoa in a semi-collapsed state (lots of sheet eased so it's spilling wind and de-powered, as Al describes, is the key).BTW, I always roll in the genoa and keep the main up when coming in, so I can still be under sail and maneuverable (read: able to tack) in case I have a stalled engine at an inopportune moment. I motorsail all the way down to my fairway this way, tidying up sheets & hanging fenders. Dropping/securing the main is the last thing I do before entering the fairway and docking into the slip. You'll call me paranoid until your engine quits on the way in in close quarters with all your sails put to sleep, scrambling for the anchor locker and winding up blocking traffic hanging on your hook. That is, if you have any room at all to drop an anchor and pay out enough line to set it. Always ask yourself, "If the engine quits NOW, what would I do?" Keeping your main up and staying to windward in close quarters whenever practicable is good seamanship, in my book.Try it. You'll like it.Jeff
