Roy Vollmer
My Hunter 27 (1983) has a low forward bow pulpit with a cross brace that houses a stainless steel mounting plate for the port/starboard running light. This assemblyrestricts the amount of space needed to install roller furling close to the headstay deckmount.What is the best solution for this condition? I do not wish to replace or modify the bow pulpit.Do I need an extension from the headstay mount to the roller furling to get above the cross brace ? in which case I loose a lot of sail area along the foot.What manufacturer would you recommend?What headsail size maximum would you recommend - 155, or 180?Thanks for any information you can supply to this request.Roy
