Roller Furler
Tim Smith
Anyone know of a cheap roller furler system? I know that most set-ups will run me around $1,000 but I wondered if there were anything that would achieve the same goal for much cheaper.
Dec 2, 1999
15,184
What size boat?
Tim; If you have a 35' boat you are not going to get much of a furler for $1000. On the other hand if you have a 23' boat, you'll get a great one in that price range. Don't forget you will need a sail for this furler or have your old one re-cut. I do not know how happy you will be with a jib that was not designed to be a roller either.
Bob Howie
Cheap roller
I can pretty much assure you that you will rue the day you try to put a cheap roller furler on your boat. It may appear to be a simply gizmo, but it's a fairly critical piece of gear given that it's on your head stay and takes a lot of strain when in use. Cutting a corner here just isn't something you want to do. Steve's right; $1,000 won't get you much in the first place. I've installed both Harken and ProFurl and they are pretty straight forward installs. If you are going to do the work yourself, it will take you about 6 hrs to do it, if you've never done it before and have read the instructions carefully and laid out your work. You will need at least one person to help you and you can install it with the mast up. Plan on installing a new head stay with the new roller; it's just a lot easier than retrofitting your existing stay and you get a totally new stay at the same time. Bottom line, on a 30-34' boat, figure $1,600-$1,800 for the roller; $150-$200 for the new stay and terminals...I'd recommend Stay-Locs...; $1,600 for a new 135% genoa headsail on a 30' or so boat, maybe $500-$600 to get your existing headsail recut and you want an extra luff pad for the furler. Toss in about $300 for some convenience goodies like fairleads for the furler line and maybe a rope cam. If you have a rigger do it, figure in $300-$500 for the installation. My opinion is that this is not a project where you want to cut any price corners on the installation of the roller and head stay. Maybe trim it by recutting your existing jib. But, I've seen this done on the cheaps before and it'll be nothing but problems in the long run.
Steve O.
Hood
The Hood systems are reasonably priced, easy to install and work OK for casual cruising. I wouldn't reccomend for serious cruising or bluewater, but if price is really an issue. Of course, you get what you pay for.
Bly Berken
Spin-Tec
On a commercial note, check out the Spin-Tec roller furling system in the HunterOwners.com Chandlery. It is an excellent system for boats 27 - 55 feet. The system is very competitively priced and is supported by an incredible guarantee. Bly Berken SailboatOwners.com
Ron Scott
Snap Furl
The Schaeffer Snap Furler is about $400 at Sailnet.com. It's for a smaller boat in the 22-25 foot range. Ron
