Roller Furler
Sep 24, 2012
55
oday 25 lake conroe
I have a Hunter Legend 37.5 with a below deck roller furler.
It seems to be hanging up more and more often.
Any suggestions on how to remedy the problem?
Feb 22, 2011
80
Hunter Legend 37 Muskegon, MI
I had a similar problem with my Legend 37. Seems that as it gets older, the metal weakens and the bearings wear out. Mine got so bad that the unit pulled apart and the bearings went for a swim. I was lucky and got a bunch of leftovers from Torresen Marina and rebuilt the lower drum. I gave up on it after the third rebuild and put on a Harken Mark IV. Problem solved. Some threads say that the halyard tension is too tight on the jib but I tried it looser and it still didn't seem to work. Good luck.
Hunter 35.5 Montréal PQ
Hello, The original system is a Hood 810 LD (for line drive) Before looking anywhere else, I would go up the mast and check if the Top Bearing at the extreme top of the extrusion is broken. Actually they call this a bearing but in fact it is only 2, 1/2 round plastic parts that keep the metal stay centered in the aluminium extrusion, no moving part. The part is worth 26$ (Pompanette.com) and is often the source of blocking problems on this unit. I own a 35.5 and had the problem as 2 other 35.5 in my area.This part can be change in 10 minutes with the extrusion/stay assembly in place. The symptoms you describe are exactly what is happening when 1/2 of the top bearing is gone.I would also investigate in the anchor well to make sure that the 2 parts of the drum assembly are not too close together. There should be 1/16" between the 2 parts. This can be adjusted by lowering the bottom portion of the drum using the Allen screw under the furling unit.It sure is worth the trip up the mast. Good luck. PS parts are eaealy available at pompanette.com
One other advise, I always unload the pressure in the sail by sailing downwind with the wind coming from + - 130 to 140 deg. when rolling the genoa. The genoa is protected by the main sail and It is very easy to furl this way. It is worth a try.
