Had it, Fixed it
I know your pain. I had the same thing with the snap furl. Two remedies (I did both):1. Buy a halyard restrainer (West Marine P# 285538) and mount it about 6 inches below the mast top on the bow side. Run the jib halyard thru it. This will bring your halyard more parallel to the swivel.2. Make a stainless pendent about 6 inches long and place it between the furler and the tack of your jib. This will raise the jib higher to bring the swivel more parallel to your newly purchases halyard restrainer.This works. The theory is the angle of the halyard to forestay is increased which greatly increases the force required for it to wrap. It works. Also, check your forstay and halyard to be certain you didn't damage them. It only takes a couple of wraps.
