I'm guessing most or all the 309s are equipped with the Selden Rodkicker vang. I'm wondering if the placement of the upper end (boom end) of the kicker has its location set by Catalina/Selden or the dealer.
In reading the Selden tips and tricks booklet for tuning the rig, they state that the kicker should never be "bottomed out" when you're sheeted all the way in under any sort of normal sailing conditions, as this will put unintended loads on the boom that can compromise it.
Well...when I'm sheeted in, sailing close on the wind, my kicker is bottomed out. Hmmmm. I'm thinking I may want to relocate the boom end just a couple/few inches further aft on the boom to allow it to have travel left when sheeted tightly. Selden says that when fitting the boom end, drill into the slot where it resides, and tap the aluminum for the three screws that hold it. Sounds easy to do.
I might check with Catalina as to who picked the original location. If my dealer did it, that pretty much guarantees that it's wrong
Another reason why I'd like to reposition it is so that I can lower my boom just a little more when furling and unfurling the main. I've heard and read advice that says to raise the end of the boom a little to ease furling. I used that advice with little success. Lately, I'm getting the boom as low as possible, and positioned the little car that sits on top of the boom way forward. Now, I'm getting greatly improved furling performance.
I guess I've raised a couple issues here. I'd be interested in:
-knowing if anyone else is "bottomed out"
-knows offhand who sets the boom end position of the vang
-just generally alerting other 309 owners about the danger of having their vang bottom out under normal use.
