Rod
Apr 8, 2010
2,191
Of course you can... thing is, that stay has it's sag modulated by the backstay tension, so the intrinsic lack of stretch in the rod is usually not worth the extra cost.
Shrouds, however can benefit from rod rigging. Like everything else, it gets back to the cost/benefit ratio.
My class of boat has been rigged with rod and wire, and unless an owner is competing at a pretty high level it probably makes a rather small difference in the real world.
7,595
Alden 50 Sarasota, Florida
Our boat came from the builder with rod rigging except for the forestry. Never gave it a second thought assuming it was done that way for a reason. No clue why...
Not sure you “can’t”. You can do what you want mostly.
Why?
Here’s a link with a couple of opinions on the idea.
Nov 8, 2010
11,386
While not as common as wire, absolutely no reason you cannot use rod as a forestay. Many Selden furlers come with rod forestays as standard.
