Rocna anchor size h41
Dec 15, 2017
58
Hunter Legend 41AC Portsmouth
Hello all and can anyone confirm what size rocna anchor I need for a h41ac as looking at the sizing guide on the rocna site it says for 12m boat and mass less than 10t (H41 is 8800kg?)
That 20kg is suitable.
Regards
NYSail
Jan 6, 2006
3,145
Beneteau 423 Mt. Sinai, NY
I have a 25kg for my beneteau 423.
About 20,000 lbs. love it.... sleep well.
Greg
Jun 14, 2010
2,365
20kg would be OK but I’d recommend a size up if it would fit on your roller. An anchor is never too big in a squall at o-dark hundred. (I have a 20 kilo Rocna on a 39’ tri and would have gone up a size if my sprit didn’t limit me. The hoop would interfere with my sprit if I go larger.)
OTOH if I was in the market today I’d look at Mantus based on the anchor resetting videos posted by SV PANOPE on YouTube. My Rocna always sets but (unless the bottom is loose sand or gravel) it also brings up a ball of seabed, and those videos show the Mantus is better at resetting. As for size, the only time we’ve ever dragged was backing down in deep oozing mud bottom, and it was a slow movement. It would have been better on that occasion to have a larger anchor or deploy the Fortress; but I didn’t due to the settled weather at the time and decided it was good enough for conditions, and we stayed put.
PS a washdown pump is a wonderful help if you get any hoop style anchor.
Likes: Parsons
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
+1 to @Captain Larry-DH . The price difference is minimal for a few kg more, and with a windlass the weight is unimportant. After the first season, I promise you will never set your anchor and think, “I wish I had saved that $75 on the anchor.” Study anchor setting and you’ll see that only scope and weight at the anchor matters, not sentinels or chain etc.
Don’t think that your boat actually weighs the manufacturer stated light weight. I’ll bet it’s at least a ton or two more. Those weights are as it leaves the factory, without sails, water, fuel, people, food, etc. Do you have the real weight that you cruise at?
Jun 14, 2010
2,365
When sizing anchors I think windage matters more than boat weight. Boats with higher freeboard, big dodgers and cockpit enclosure, and multihulls should size up.
Gunni
Mar 16, 2010
5,937
Your boat sailing ready, provisioned and loaded with crew most certainly weights more than 9,000 kg. When I switched to the Manson Supreme (similar to the Rocna) from a CQR I was struck by the much larger fluke area of the Manson. Find that it sets and holds well on short scope. Size: 60 lbs., all-chain 10mm BBB.
Oct 27, 2016
0
Seattle
And now a word from the sponsor...
Replacement in-deck solar panel
Finally, a drop-in replacement for the in-deck solar panel on Hunters built from the early 90s through the mid-2000s. Improved for longer life and greater output.
See the product
Jan 12, 2016
272
Hunter 410 Ladysmith, BC
I have a 25 kg Rocna on our Hunter 410. It fits, and is easy to set. Very happy with the anchor.
