My boat Ponteneur V3283 was purchased in the Netherlands and has an RM69 Sea Toilet fitted. Has anyone fitted the Buffer Tank - Surround Shape available from RM69 into a Vega? My concern is the waste outlet connection as currrently this is a snug fit with the waste outlet elbow joint from the toilet pump just fitting to the seacock. When fitting the Buffer Tank an adapter has to be fitted to the toilet pump and I am concerned that this will not align with the seacock outlet.
The toilet just fits into the heads allowing the door to close so there is not much room to realign the toilet if the Buffer Tank adaptor will not fit without moving the bowl.
Any help much appreciated.
David Wisdish
V3283
David Wisdish
V3283
