Ed's right...It has to be a combination
Hard pipe should never be directly connected to anything else "rigid"...'cuz any shock or stress--even banging the dock hard--will put stress on the connection and can crack the weaker side of it. A hairline crack in rigid PVC may not allow liquid to escape, but it certainly will allow odor to escape. And when it's connected directly to a holding tank, it's almost always the welded fitting in the tank that lets go, not the pipe that cracks. So it's necessary to "soft couple" any hard pipe with about a foot of hose to act as a shock absorber when connecting to a toilet, thru-hull, pump or tank. And, as Ed mentioned too...it's ok for long straight runs, but there aren't many of those on boats. Every bend requires inserting a radius fitting, which mean cementing a union into it...and every union becomes a 'bump' in the pipe to trap bits of solids and paper.IMO, hard pipe makes sense only on boats large enough to have 6-8' straight runs (much longer than 8' and the tank is too far from the head anyway)...not in any other circumstances.If you'll tell me what site the discussion is on, I'll be glad to drop by and answer questions.
