I recommend that you check here. www.olympicpropeller.com
You will need to provide engine model, gearbox model with gear ratio and shaft diameter. They can help you with your prop needs.
I have a 2000 H340 with the 3GM30F engine. I replaced the factory installed two blade with a 3-blade RH Campbell Sailer 15 X 9 X 1. Great power, very little vibration, less drag. www.westbynorth.com
