papa steve
I'm a new hunter 23.5 owner and I'm familiar with the set up on the boat without a furling jib. But my boat has a furling rig and on my first set up on a dry run, I found I had to set up, then unfurl the jib, drop the sail, and then raise the sail with the jib halyard I had used for set up. Are there any short cuts? Other than adding a spiniker halyard? Also on the breakdown If I drop the jib to use the halyard again. I won't be getting it furled again. What am I missing?
