Loos Gauge
Hi Jim -I haven't been able to find the recommended numbers for specific boats, but the Loos gauge does give you percentage of breaking strength.  12-16% is a range I've heard people use.  It's important to make sure your mast is in column, so the Loos Gauge helps to equalize the tension on the port and starboard shrouds.  Experiment with a setting, then go sailing an note how much slack is present in the leeward shrouds.  Test both sides and make adjustments so that things are equal on both sides of the boat. Hope this helps,Trevor
