Rigging tension
May 17, 2011
10
Hunter 27 Clearwater fl
I hope someone can help me with the following: what is the spec for the rigging tension...1979 hunter 27 ft...or where can I go to obtain the specs...thank you
Oct 14, 2005
2,191
Dellcom...
Borrow or buy Loos rig tensioning gages that fit your rigging. Specific numbers aren't used, but a percentage of the wire's breaking strength (usually about 15%) is the usual guideline for tensioning the standing rigging using one of these gages. These gages will show the tension on a scale (the Pro series can be left in place on the shroud while a turnbuckle is adjusted and the tension read).
