Bob Getchell
I bought a 25.5 and it came with a whisker pole and a "spinaker" that the previous owner had never used. Ill describe the sail. It is in a sleeve that has a couple of hoops on it. Has a detatchable cheek block with it. The three corners are labled Head, Tack, and Clew, and there are lines attatched to the Tack and Clew. One is short about 10 feet long, too short to run back to the cockpit, the other is long like the sheet on the jib. The boat is not rigged with any extra halyards, winches, cam cleats, fairleads, etc. that would be used for a standard spinaker rigging. The whisker pole doesnt seem to have any place to rig a line like a topping lift or downhaul etc. Any advice on if I can use this sail, or would it be worth adding rigging to facilitate. The sail looks like great condition. Thanks, Bob Getchell
