Our 1985 Catalina 30 Mk I has two reef cars on the Starboard side of the boom. At the forward end of the boom there are two cleats. (No lines for the clue) On the luff, there is a line going from a cleat on one side of the mast thru the eye for the lower tack reef (two reef points) and down the other side of the mast to a second cleat. No horn. The outhaul comes down the side of the boom and is currently wrapped in a figure 8 around the two forward boom cleats. The boom looks like the old style kind that rotates, although I can't see how since it has mid-boom sheeting...
This post is as close as I found to my setup, but it is not quite the same. (His is a Mk II) I don't have the reef lines led aft as in the picture in the post. If the two boom cleats are for the 2 reef lines, where does the outhaul terminate?
Can someone tell me or point me to a source that would tell me how this is to be rigged?
