Rigging Measurements...
A
Anthony Bavuso
I went out to my boat the other day and took some rig measurements because I am planning on purchasing new sails soon. I noticed that my P measurement is not the same as the specs. Has anyone else measured their 25.5s rig dimensions? What were they? I measured the P from the gooseneck (note: not the tack pin, I have the mast down on saw horses and that was the easiest to measure) to the masthead sheave. So the actual P measurement is going to be even less than the 26' that I measured. But the spec P is 26' 5". So my P is at least 5" too short. Did the boat specs change or is it just my boat? Here is what I found: Mast height from base to masthead sheave: 341" From base of mast to gooseneck: 29" From gooseneck to masthead sheave: 312" Thanks for all your help.
E
Ed Schenck
Have the loft measure.
When I bought a new mainsail the loft would not use my measurements, they wanted to get their own. They don't charge for getting it right.
A
Anthony Bavuso
Mail order used sail warehouses...
Thanks for the good suggestion Ed. In my post I said I was getting new sails but I meant 'new, used' sails. I wished I could afford getting them made brand new in which case the loft would take the measurements. But I can't so I am getting used sails and have to take the measurements myself.
Dick Vance
All Inches Are Not Equal?
Anthony, I can't explain the difference but the "Official" P for all 25.5's is 26' 5". I measured mine at 26' 61/8" to the top of the boom using a steel tape hoisted with my halyard. It is 1/2" from the top of the boom to the bearing surface of the tack pin. There could be a variation in using the tape-hoist method due to shackle and eye-splice size. I have a written quote from JSI which reflected 26.42' (converts to 26' 5.04") from their stock dimensions. I have shopped used sails in the past and have had some success with jibs but have never found a decent main that would fit. Because the main is the one sail that is up all the time, I'd really recommend a new one. Here are some links to sources of used sails: http://www.sailmaker.com/ http://www.sailexchange.com/ http://www.usedsails.com/ http://www.galaxymall.com/commerce/minneysails/ HTH Dick Vance H-25.5 "Honey Bear"
Rick
Oct 5, 2004
1,098
Hunter 420 Passage San Diego
Hunters vary
Hunters have a reputation for substantial varition in measurements. Apparently, your gooseneck is mounted in a fixed location. If you could move it down you could get a main with a longer luff. Finding the "right" main in the used sail market is likely to be problematic. I bought a new 155 last summer from Rolly Tasker and think its a good sail. I often beat faster boats with much more expensive sail in our racing fleet. I'd recommend saving up for a new main. If you wait till the boats back in the water you can probably get a more accurate measurement. Don't forget to allow for differing amounts of luff tension. Good luck.
