Rigging lines for my Jib
Jim Bellesbach
Help, I have just purchased a 1995 23.5 Hunter. Enjoy the boat a great deal, but I think I don't have my lines run correctly. I have searched for an owners manual with no success. Would really like a diagram. Any suggestions. Jim
E
Ed Allen
best source
jim, the link will take you to a 240 manual that effectively covers the 23.5. the jib sheets just run through the blocks mounted on the deck to port and starboard of the mast. then lead back to the cockpit where they are tied off on a jam-cleat on one side or the other depending on your tack. hope this helps. - ed
C
Crazy Dave Condon
sheets
Jib sheets run backward between the mast and shrouds to a turning block on a stand up spring on the deck on both port and starboard sides. YOu will see the blocks on top of the deck adjacent to the sea hood or slider hatch about mid ships of the slider hatch. The lines will run back to either a cleat, cam cleat or what ever. I hope this helps you.
