Rigging Hunter 25
C
Carlos Silva
I'm replacing the old rigging in my 1978 hunter 25 but I’m not 100% sure about the measurements. Existing rigging was not the original and I don't fill confident with it length even when are pretty close to following lengths. I got this from archives. ________________________________________ Standing rigging specs for h25 Submitted by Jim on 03/02 at 01:14PM regarding Hunter 25 The good people at Hunter Marine provided me with the following for the h 25: Headstay----- 31'51/2" Backstay----- 33'23/4" Upper Shrouds----- 29'101/2" Fwd. Lower Shrouds----- 16'13/4" Aft lower Shrouds----- 16'33/4" Wire size is 5/32, type 1x19. This boat will reward your labor well. Best Regards, s/v Cygnus Jim _______________________________________ These measurements refer to the actual pin to pin or to the whole assembly with turnbuckles close? If this is the pin-to-pin how many inches I shall subtract to get an adequate pin to pin with 9-1/4" turnbuckles close? Also the original manual indicates different lengths. Thanks, Carlos
Bill O'Donovan
Go long
You can always trim out using a soldering gun. If you're short, you're screwed.
