I JUST DID MY 1981 H27
I just bought a sweetheart of a 'deal' for $1200 a few months back. The hull and decks were in good shape, below decks was a mess, but mechanically, things seemed okay. However, after fixing some things up, completely cleaning and replacing many interior components, and even sailing it a few times, I decided to have a professional rigger look at the rig. It was worth every penny. When he went up the mast, he found small divots and kinks in the shrouds and forestays which can significantly reduce the strength of the wire. He also found that the upper pin holding the forestay to the mast, was partially dislodged and was working its way out of the fitting. I was a few millimeters away from dismasting myself. At any rate, he recommended that the standing rigging be replaced, and offered to powder coat the mast, boom and associated hardware for me. The total bill comes to about $2,200 for new anchor light, windvane, powder coat mast, boom, and spreaders, minor crack weld repair to spreaders, new spreader tips, all new standing rigging (3/16X19 ss wire), swaged ends, new lifelines all around, new outhaul, and new vhf antenna... I was seriously thinking about trying to see how far I could get on the current rig, but in hind sight, my decision to hire a professional rigger was a great one. He found things I would not have looked for, and as a benefit, I have been paying attention to everything he does, so I can do my own inspections in the future. It is worth the money to have a professional rigger give you the peace of mind of having a rig that is safe and can withstand the abuse that a sailboat underway can take on. Just shop around a bit, and the price should come down. Plus, many riggers will come down on prices if you bargain wisely. Even if the mast is older, and may have light corrosion, as long as there is no cracking or large pits in the surface, just cleaning it up, and re-coating it professionally will do the trick without having to buy a $2,500 mast...Chris
