Rigging adjustments
pahuac
Jun 4, 2004
13
2 Philip Rhodes Truant Callao, Peru
I am just about to finish a complete replacement of the shroudes on my 30' fractional rig Phillip Rhodes and facing the question of how much tension should I place especially on the jumpers. Does it depend on the length of the mast, the jumper section, the strut or a combination of all these?
Thanks,
Jun 13, 2005
559
Irwin Barefoot 37 CC Sloop Port Orchard WA
The jumpers should be tight enough to support the upper section of mast so that it is straight when the backstay is slack. but loose enough to allow the top of the mast to move aft just enough to get a smooth and uniform bend from the mast head to the step, when the backstay is set up hard. The amount of bend you set in, is a function of the draft in the mainsail and should flatten the main only enough to take a portion of the draft out, not all of it. Your mast partners should hold the mast centerline but allow it to move forward at the deck to produce that smooth bend all the way to the step. Uppers should be set up tight initially because they will ease off as you induce bend. Lower tension is a matter of choice. Some like the aft lowers loose to allow the mast to kick forward a little when under chute with backstay off. Others like the fwd and aft lowers equally tight to to hold the center of the mast fixed. I like the former in heavier air and the latter in light,
Good luck.
Joe S
TimCup
Jan 30, 2008
304
Catalina 22 St. Pete
Mr. Shirley, great answers.
And not to hijack a thread, but welcome back. Haven't heard from you in a while, hope all is well. Your contributions are, for me, always informative.
cup
Jun 13, 2005
559
Re: Mr. Shirley, great answers.
Thanks for the praise but I have been looking in from time to time. The answers that I have seen are usually so good, that I haven't have much to add.
Thanks again
Joe S
pahuac
Jun 4, 2004
13
Cannot agree more with TimCup's qualification of your reply.
Thanks a lot,
