Reply to Greg
Assuming you have the Z-spar mast, you may need more tension on the lowers (at least 400 lb) because they contribute the most to keeping the mast vertical (measured side to side). The tension in the uppers will affect the ability of the top of the mast to bend to leeward. What you want is just the top of the mast to bend slightly, not the whole mast to lean off to leeward.This will reduce the heel, while keeping the lower portion of the main powered up.  Your boatspeed should not fall off, in fact it may pick up a bit because less heel means less wetted surface and less weather helm, and therefore less drag.Yes, with the reduced headstay tension the backstay will now be almost slack (mine is) until you tension the jib halyard. This is where the payoff is, because now you can adjust jib luff tension as well as mast bend for different wind conditions.In light air, easing the jib halyard will give you a fuller jib. Less halyard tension also means that you need less backstay tension, so you end up with only a little bend and a full, more powerful main. Remember, rake and bend should be measured with the boat at rest with no wind loads on the rig.As the wind picks up and you tighten the jib halyard, you have to increase backstay tension at the same time to maintain the same rake. This puts more bend into the mast, which flattens and depowers the mainsail.  With reduced tension in the forestay, it shouldn't take as much force to tension the backstay to where you want it.I have seen people adjust the backstay using a piece of half-inch line with a small bowline tied in and pulled straight down to a cam cleat on the transom. I have also seen more elaborate setups, including the triangular plates with the wheels. I am going to start simple and keep it that way until I find something that works better. Unfortunately, I am cursed with light wind from now until November, so it may be a while. Maybe I should go slap on some fresh VC17 on the hull in the meantime? Good luck.PeterS/V Raven
