Rigging a cruising spinnaker
1,446
Hunter H260 Traverse City
I'm ready to rig a new asymmetrical and wonder about what to use to attach the tack to the "bail" of the anchor roller. Also, any idea of the forces on that bail? Are the welds there usually of sufficient strength? Thanks.
Jun 2, 2004
40
Hunter 430 Schooner Cove, B.C.
Rigging a Spinacker on a 430
George, When I use the cruising spinacker on our 430, I attach a block to the bail at the end of the bow sprit. I run a line through the block to a plastic sleeve which fits around the furled head sail. The tack of the spinacker is also attached to this sleeve (the sleeve was purchased from ATM who made my spinacker sock). The line is then run back to the cockpit which enables me to easily trim the luff of the spinacker. If you have the same bail as we have on our bow sprit, it is more than adequate to take the load of the spinacker. Peter Milne S/V Blue Heron
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Don't
...attach the tack to the anchor roller. Instead attach a block to the roller bail and run a line from the tack through the block and back to the cockpit. This way you can adjust the tack height and luff curve for various AWA.
Aug 11, 2006
1,446
Peter...
Hi, Peter, Do you possibly have a digital photo of this setup to send me? Thanks.
Jun 2, 2004
40
George - 430 Spinacker Setup
George, If you send me an email address, I'll send you the photos that I have. Peter S/V Blue Heron
