Slack
There shouldn't be any slack, ever.The point of tensioning the rig isn't to make it sail well, it's to keep the mast from falling down. If there's any slack in the wires, then the shock loads are much greater on the wire, the chainplates, the hull, the tangs, the masthead, the fittings, etc. If you have slack on leeward wires and you are bouncing around in rough seas, think of the pounding that's being imposed on your equipment.Just as uncontrolled jibes are a bad thing, so are uncontrolled mast movements.If you just want to sail well, you can adjust the standing rigging for the appropriate rake and mast bend and then leave it pretty much untensioned. If you want to sail well AND not create undue stress, then I'd suggest you tighten things up.
