Outboard highriders
Hi Kenny;You probably need a long shaft (20" to 25") outboard for the 25 O'Day. The motor mount may also be a tad too high. Measure the distance from the top of the engine mounting flange on the motor mount to the waterline. Compare that measurement to the same on the motor (under the bracket screws to the cavitation plate)You should keep the cavitation plate of the motor underwater as much as possible. The engine's water intake is just under it. If the cavitation plate is high and dry, your water pump on the motor is as well - not a very good thing for impellers! This is evidenced by the motor revving when the boat's in a choppy sea.A quick fix is to remove the mounting plate and cut off a inch from the top if that'll do. Otherwise, you'll need to relocate the mount lower, or get a mount with greater vertical travel distance. If all else fails and you have $2000 to part with - get a long shaft outboard. Honda makes a 25" model, but most 20" models should do. Outboards come standard in 15" shaft lengths usually.Be careful - with a longshaft model, you may not be able to tilt the motor so that the lower end is completely out of the water depending on the motor, motor mount design and installation height!Good luck.Stu"Karakahl"1979 O'Day 22 CBCenterport, NY
