Rhombline
Ross
Jun 15, 2004
14,693
The rhumbline is the
course on the chart that you follow from start to finish. if you are reaching then you can follow it directly but if you are beating then your tacks take you to the left and right of the line but at the end of the day you plot your progress along the rhumbline. On an ocean crossing your rhumbline would be a "great circle" route.
Jun 2, 2004
12
Freedom Freedom 45 Barrington, RI
Not a Great Circle
From the wikipedia article on rhumb line (http://en.wikipedia.org/wiki/Rhumb_line): "In navigation, a rhumb line (or loxodrome) is a line crossing all meridians at the same angle, i.e. a path of constant bearing." The route would look straight on a Mercator projection map but on a globe (or the face of the earth) the route would be curved, i.e. it would NOT be the shortest distance between two points. Compare with the wikipedia article: http://en.wikipedia.org/wiki/Great_circle
Da Capo
mostly correct
Ross is mostly correct. The rhumbline is the direct line from point A to point B. As a saiboat can not usually sail the direct line from point to point (even reaching and downwind sailors must take into account current and wind ....."set and drift")
John G.
Keep it simple
I think the first posting (Ross) could not bave put it better. It is as simple as that.
Oct 3, 2005
159
Catalina 387 Hampton, VA
Humor:
If you are having problems with a Rumba line, maybe you should watch Dancing with the Stars. (OK bad joke, but it was just sitting waiting to be said.)
Ross
Jun 15, 2004
14,693
I could have gotten
out my copy of the American Pratical Navigator. But sometimes when someone wants to know the time he doesn't need to understand the meaning of time and how a watch works.
Joe
Jun 1, 2004
8,184
thanks, Eric
for a very concise and accurate answer to the question "what is a rhumb line?" I myself appreciate knowing how a "great circle route" differs from a "rhumb line" and I can also appreciate someone taking the time to research and validate his response. Ross, must you be so petulant?
