Revised Fresh Water Maintenance guidelines
Stuart
Hi Peggy, A while back, you mentioned that you'd revised your fresh water maintenance guidelines. Searching the archives, I could only find the original guidelines. Could you post the revised article again? Thanks, Stuart
Peggie Hall/HeadMistress
You prob'ly found 'em
'Cuz it's been at least two years since I revised 'em. But here they are again (Btw, this also gets rid of antifreeze taste and smell): Turn water heater off at the breaker before beginning. Do not turn it on again until entire recommissioning is complete. 1. Prepare a chlorine solution using one gallon of water and 1/2 cup Clorox or Purex household bleach (5% sodium Hypochlorine solution ). With tank empty, pour chlorine solution into tank. Use one gallon of solution for each 5 gallons of tank capacity. 2. Complete filling of tank with fresh water. Turn on every faucet and allow water to run until what's coming out smells strongly of bleach. 3. Turn off faucets--but do NOT turn off the pump...it must remain on to keep the system pressurized so that the solution remains in the lines. Allow to stand for at least 3 hours, but no longer than 24 hours. 4. Drain the tank through every faucet. 5. Refill tank with clean fresh water and drain again through every faucet. 6. To remove excess chlorine taste or odor which might remain, prepare a solution of one quart white vinegar to five gallons water and allow this solution to agitate in tank for several days by vehicle motion (iow, go sailing and tack a lot). 6. Drain tank again through every faucet, and refill with potable water. The above recommendations conform to section 10.8 in the A-1 192 code covering electrical, plumbing, and heating of recreational vehicles. The solution is approved and recommended by competent health officials.
Stuart
Thanks Peggy
You definately give the most useful, clear-headed advice on the site. Stuart
