My 2002 Hunter 356 began experiencing issues recently with not going into reverse. I have a Yanmar 28hp engine. It goes into Fwd find however no thrust in reverse. The gear shift seems to work fine with the shaft spin increasing with throttle in fwd and reverse...but no thrust in reverse.
Suspecting a glazed clutch we have tried replacing the ATF with diesel and an additive to dissolve the deposits and get the cluthc to re-engage. No luck so far.
Has anyone else experienced this issue? Words of wisdom or advice? Thanks.
