I am considering installing a EnviroComfort reverse heat/cool air conditioner. This unit draws water from a through hull fitting. My question is: is it acceptable practice to T-off an existing through hull fitting. I was thinking I could use the through hull fitting from the cooling system to the engine. The Air unit has its own water pump. The Air unit would not be running at the same time as the motor, so I'm thinking this may not be a problem. Any comments ??
