tiger 37373, Maybe not so foolish
Most boaters would prefer a reliable refrigerator; the small water-cooled unit you installed can not be counted on for extended or continuous operation. Check some of the Forum archives and you will see the how these systems perform. On pleasure boats when the refrigeration compressors are larger than 1/6 Hour power the process heat is almost always removed by seawater. Water cooling these small refrigeration systems with BD compressors is a mistake for many reasons, pump failures, pump air locks, screen clogging, additional amperage is required over air cooled, and total destruction of a system when the seawater inters the refrigerant circuit. With the older model fixed speed compressors there can be an improvement in efficiency when sea water temperature runs between 55 to 70 degrees F. On systems using the new Danfoss variable speed compressors the added current required to drive a pump offsets the efficiency gained by running the compressor at a slower speed in most small boxes or cooler climates. There is one serious problem with using water cooling with the small Danfoss BD compressors, many of the small seawater condensers have failed do to electrolysis corrosion and this allows seawater to mix with the refrigerant and destroy the complete system.If you are a weekend sailor, and don’t leave the refrigerator on while at the dock, and don’t have an onboard generator, you could have good success with your system, if you stay in the seawater temperatures around San Diego.
