Steve
reconditioning
Hi, No experience with having the hull painted, but I asked a guy at the boat shop about repainting my 26X and he led me to believe it would be into triple digits. I'd rather take my chances on a do it yourself job than pay that much. In the West Marine catalog, on p.465 is "Trewax" fiberglass rubbing compound 24oz for $14.99. "It strips away oxidation and chalking without damaging gel coat." Probably about 5 of those and $2-$300 worth of time and elbow grease...you definitely are going to have to use some kind of rubbing compound..I've had good results with any of the Meguiar's stuff. Try the fiberglass color restorer, or the heavy duty oxidation remover on p.467. It will be a lot of work doing it by hand, but mechanical buffers could wreak havoc if the gel coat is thin. If you have gotten it clean enough, you might just decide to roll on the best paint you can affordon the deck, and spray the hull, and roll on below the waterline. You can buy paint sprayers pretty cheap nowadays..It's your boat, and you can paint it any color you want..be conservative or outlandish..I'm sure that if you're careful, it will look 100% better when your done. Not much help, am I? It's just that a long time ago, I quit thinking about how things should look, as opposed to how I would like things to look, and I've been happier ever since.
