Cut them out with monofiliment line.
Michel:The easiest way to get the old lenses out without breaking them is to use some high test fishing line. All you need to do is cut out a small piece of the caulking on the edge (inside and out). Then fish the line through the hole. Have someone hold it from down below and another from above. Then just pull it around the opening and viola, the lense pops out.When you get the lense out, you should make a basket on the inside of the boat. This is just some newpaper taped to the interior to catch all of the old caulking when you scrape it off the port opening. Clean the opening very well before you start the install process. Mask the deck area before you start caulking. Also put making tape on BOTH side of the lense before you reinstall. Be sure that there is no tape on the area that will come into contact with the caulking. Once the caulking gets a SKIN on it you can strip off the masking tape and you are good to go.Be careful if you lenses use screws. This is an area that can be a source of the leaks.
