Required items
Hello Don,Thanks for your note. For the Max-Prop you will want to re-grease each year and replace the tip zinc, if yours is equipped with one. If you experience any electrolytic scaring you will want that fixed as soon as possible.The PSS will need to be burped each time the vessel is pulled from the water and set back in. If the water drains from the tube and air replaces it an air pocket can form which could allow the seal to run dry creating heat and possible scoring to the carbon surface. The instruction manual at www.pyiinc.com talks about it. As with any hose clamp on board you will want to tighten or replace as needed. Hope this helps.Kevin
